FAQs
Where Should I Install My Alarm Panel?
Answer
The alarm panels sold by Surety can be placed on a desk or table-top via the included back-stand or they can be wall mounted. The panel uses a cellular communication method for primary communication with wifi backup. This means the panel should generally be installed away from large metal objects in an area of your home at or above ground level. Do not install the panel in a basement.
If you plan to wall-mount the alarm panel, it is recommended to test the panel in your desired location before mounting it.
