Help Forum
2Gig to Qolsys upgrade/conversion
Support 2Gig to Qolsys upgrade/conversion
Viewing 8 posts - 16 through 23 (of 23 total)
  • Author
    Posts
  • #171330
    Russel
    Participant
    Thus far I am not able to get the QS1137-840 to work with the 5150, it reads it as “open”. Qolsys provides nearly zero details on using this aux input on the sensor, perhaps the 5150 doesn’t provide enough resistance to register as “closed”?
    #171346
    Tyler
    Tyler
    Surety
    The Aux is programmed into the panel the same way you learn in the internal reed switch. Wire up the terminals and trip the sensor to learn in. Some additional info:
    You can only use the reed switch or the aux terminals, not both
    Max length is 3 feet of wire. No resister is needed
    #172836
    Russel
    Participant
    So far I have been unable to get the 5150 to trigger any events with the QS1137-480. I have smacked it pretty hard and nothing seems to register, tamper registers reliably…as would the magnetic reed switch, but not the aux input.
    #172860
    Jason
    Jason
    Surety
    I’m double checking with Qolsys to be sure there aren’t any sensor group limitations or firmware concerns.
    #172866
    Jason
    Jason
    Surety
    Aha, I think I see what is wrong here. The manual does not indicate this, but both zones are active at once. The panel will receive the open from either one, but the reed switch needs to be closed for the wired input to open, which means the sensor’s magnet must be closing the reed switch. Any luck with that?
    You cannot use it as two separate zones, it just acts as a single zone.
    #173018
    Russel
    Participant
    I have to say, the entire void of accurate documentation on these sensors is a bit frustrating. I understand that the documentation may not be for “homeowners” and be more complicated, but the fact is that there is an entire lack of documentation the use of this AUX input.
    What you are saying would make sense of the 2 sensor inputs (reed switch + AUX) were wired in a series, and the AUX came with a jumper in place…as then whichever input “opens” would break the loop and trigger the event.
    In actually working with the sensor using the 5150 it has been so unpredictable, it seems like each time I try to test with it I get different results. Previously the reed which would operate when I had the AUX “closed”, but the AUX itself wasn’t reliable for triggering an “open”…in fact I was never able to get the 5150 to trigger an open, including when hitting it directly with a mallet. I gave up, had unpaired it and it has sat for a couple of days.
    Today I pair it again, the 5150 has been connected for “some time” now…and now the reed switch accepts no input (it never opens), however the 5150 does work. So perhaps it is that you need to remove the batteries from the QS1137, connect the AUX and then place the batteries back in…as perhaps it changes which input it is watching based on if the AUX is “open” or “closed” on initialization? It seems that if AUX is “open” on initialization, the reed switch is active…if the AUX is “closed” then it becomes the active input.
    Perhaps I will test my theory when I get some more time/patience to deal with this, as I find the lack of documentation to be entirely frustrating.
    #173051
    Jason
    Jason
    Surety
    I understand the frustration. We will do some testing on this and report back to confirm the operation.
    #250181
    Russel
    Participant
    For anyone else that encounters this, it does seem you need to have the auxiliary input connected/closed prior to installing the battery. At that time it will disable the magnetic reed switch and only use the auxiliary input.
    So far the 2 QS1137 are working fine with my 5150 shock detectors, I just hope they never have to “work” outside of testing. At least my highest threat door is now protected again, even if it did result in having to have 2 door mounted sensors (one for glass shock, one for door open/close).
You must be logged in to reply to this topic. Log in or register here.
Value Proposition
Your home is your domain.
Connecting you with it is ours.
Learn about Surety whole home automation and security.
Just need cameras? Check out Surety 24/7 AI powered video.
Whether you’re a security system novice or a seasoned pro, everything we do is designed to make monitoring your Surety Home incredibly simple and enjoyable.
Guy Relaxing in Chair
New title
Five out of five star rating.
“(They) are very quick to reply with thorough, knowledgeable, complete and helpful answers… I really can’t say enough about how impressive they are…. I am a huge fan and would highly recommend…”
G.N. , Westfield, NJ , Yelp , 7/03/2018
“Could not recommend enough. The service is excellent and the price is unbeatable. We switched from another company where we felt like we were being taken advantage of; but not with Surety! This has been the best move for home security.”
Melissa C. , Citrus Heights, CA , Yelp , 4/26/2018
View more
Plans
We offer plans to fit everybody’s needs.
Shop Plans
